High Cpu Utilization
prateek_jain12
Dears,
I am seeing High Cpu Utilization on Layer 3 Switch
L3#sh proc cpu |  ex 0.0
CPU utilization for five seconds: 66%/29%; one minute: 68%; five minutes: 68%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  12    14628298    14665951        997  0.47%  0.55%  0.54%   0 ARP Input
  85    22621780    15197258       1488  0.47%  0.80%  0.85%   0 RedEarth Tx Mana
  91   101243226     1513576      66890  2.23%  2.36%  2.34%   0 Adjust Regions
107     7724784   117247467         65  3.67%  3.45%  3.35%   0 HLFM address lea
125   293573384   174160026       1685  7.67%  8.24%  8.05%   0 hpm main process
129    39328856     4160564       9452  0.79%  0.90%  0.89%   0 hpm counter proc
169   139560067   101457486       1375 10.39% 11.45% 11.72%   0 Hulc LED Process
181     9792691      825335      11865  0.47%  0.27%  0.26%   0 HQM Stack Proces
214    22859017    40738557        561  5.75%  3.81%  3.62%   0 IP Input
Pls suggest.
6 Replies 6
ALIAOF_
Level 6
Level 6
Is it constantly like that?  You have to look at all the processes and see which process is causing high CPU usage.
Leo Laohoo
Would be helpful if you can provide the complete output to the command "sh version".
InayathUlla Sharieff
Hi Prateek,
I believe you are having Cisco 3750 Switch?
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD)
detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
My collegue has recorded complete information on this in  the following link :
https://supportforums.cisco.com/message/3862968#3862968
If In case it is Cisco 4500 device collect the following outputs:
show ver, show log
show platform health
     - show platform cpu stat
show platform cpu packet statistics
Inayath
*Plz rate all usefull posts.
pratik gandhi
Hi prateek,
From ur cpu processes i can see there is lots of intruppts causing ur cpu hike
Try to remove ur qos policies and then have a look at cpu processes
Partha Dasgupta
Hi Prateek,
As per the output provided it looks like you have software forwarding  going on your CPU.
Check your IOS version. you might be hitting with Bug CSCsm26985 3750 misses hardware forwarding information in certain condition
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsm26985&from=summary
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If you're doing software forwarding, problem might also be incorrect SDM template (if the device offers SDM choices) for the traffic flowing through the L3 switch.  (It's also possible that nature of traffic can exceed the resources of any available SDM template resulting in software forwarding too.)
