HIGH CPU WS-C4503-E IOSD
jbriones
I have a switch C4503 -E , I seen an increase in CPU with a monitoring tool , without detect a low performance in network for this cause.
I have seen with the command ¨SHOW CPU PROCESSES SORTED¨, an IOSD process It is the one that most increases but network users have not experienced some connectivity problem. Can you support me?
thanks in advance
Leo Laohoo
The process "iosd" usually means the CPU is overwhelmed by too much traffic from a specific or series of interfaces.
Look at each of the interface which has very high (and incrementing) total output drops and this (or they) will be the cause.
