High CPU
,,Hi all
I upgraded to a  Cisco 1941 ( from 1841)
I applied the access list below to the provider facing interface. And there a 2 issues as result of this. When I run a speed test I typically download about 60 Mbs when it should be 90. If I remove the access list from the interface it will consistently hit 90 all day. CPU spikes and hits 100 % during these test. I captured the CPU process below in the middle of a speed test... My question is,,,is this normal? Does NAT have anything to do with this>? I am hoping I have something set wrong that I can correct > If that's not possible this 1941 is a letdown
Thank you in advance
HS1941#sh processes cpu | ex 0.00
CPU utilization for five seconds: 93%/37%; one minute: 37%; five minutes: 14%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
82 356 403 883 0.79% 0.25% 0.06% 132 Virtual Exec
116 72 199824 0 0.07% 0.04% 0.02% 0 IPAM Manager
120 100264 128767 778 54.31% 21.19% 7.63% 0 IP Input
234 104 200011 0 0.07% 0.05% 0.06% 0 PPP manager
Extended IP access list 110
10 deny udp any any eq netbios-ss
20 deny udp any any eq netbios-ns
30 deny udp any any eq netbios-dgm
40 deny tcp any any eq daytime
50 deny tcp any any eq chargen
60 deny udp any any eq 19
70 deny udp any any eq 1900
80 deny tcp any any eq 1900
90 deny tcp any any eq sunrpc
100 deny tcp any any eq exec
110 deny tcp any any eq login
120 deny tcp any any eq klogin
130 deny tcp any any eq kshell
140 deny tcp any any eq 135
150 deny udp any any eq 135
160 deny tcp any any eq 137
170 deny tcp any any eq 139
180 deny tcp any any eq 445
190 deny udp any any eq 445
200 permit ip any any log (370076 matches)
interface GigabitEthernet0/1
ip address dhcp client-id GigabitEthernet0/1
ip access-group 110 in
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex full
speed 1000
no cdp enable
end
2 Accepted Solutions
Hi marcjohnson231@gmail.com
  As the CPU gets high the capacity of router's packet switching probably decrease  thus slowing the throughput.
  The question is why CPU gets so high. You ACL could be the reason as the router needs to process so many statements until decide if packet can send out on the interface or not.
 Can you show the whole output of 'show proc cpu' during the spike ?
-If I helped you somehow, please, rate it as useful.-
Joseph W. Doherty
Cisco recommends a 1941 for up to 25 Mbps.
Can a 1941 pass more than 25 Mbps? It can (as you've noted), but its capacity will vary much with its configuration and traffic mix. The 25 Mbps recommendation can generally be met with most configurations and/or traffic mixes.
Anything you can do? Perhaps there is. You might try removing logging from your ACL 110's 200 statement and/or activate flow caching.
Joseph W. Doherty
Thank you
As soon as I removed the " logging" statement the high CPU lowered significantly  and the throughput  was able to achieve 90 Mb with the access-list applied/
