12-06-2017 08:29 AM - edited 03-08-2019 01:01 PM
We are having Model: Cisco Nexus 5672UP Chassis with Fex: Extender Model: N2K-C2232PP-10GE and they all are running on kickstart: version 7.2(0)N1(1) :System: version 7.2(0)N1(1).
We are planning to connect 3 Router ISR4451-X/K9 with Version 15.5(3)S6 to the nexus and run EIGRP.
I have design in the following way.
I want to create L3 port channel on router and also on nexus and run EIGRP on them. But I came to know Nexus 7.2 has some Port channel issues when running EIGRP.
Can anyone suggest how we can effectively design with redundant connections with out upgrading nexus?
Satya.Mothukuri
12-06-2017 09:13 AM
I recommend you to check first the following link: https://www.cisco.com/c/en/us/support/docs/switches/nexus-2000-series-fabric-extenders/200363-nexus-2000-fabric-extenders-supported-un.html
in order to improve your design.
After that, you can check this other link: https://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_L3_w_vpc_5500platform.html#wp999181
in order to see a recommended topology for your case.
12-06-2017 09:45 AM
Thanks for the reply Yachay,
So the ideal way to connect router to nexus :
The router connects with Layer 3 interfaces 1.1.1.2 and 2.2.2.2 to the two vPC peers and these interfaces are not part of a vPC port channel.
I want to know if this is limitation on 7.2 and in 7.3 was this addressed?
Satya.M
12-06-2017 11:11 AM
For 5Ks, that limitation was lifted on 7.3 (with the layer3 peer-router configuration.) But, according to some colleagues, Cisco told them that using dedicated layer 3 links is the best way to avoid any issue.
