High input/output error on interface 'AppGigabitEthernet1/0/1'
schumad2ccf
Hello Everyone, My DNAC instance is reporting high input/output errors for every single 9300 i have in inventory for interface AppGigabitEthernet1/0/1. We don't even use Application hosting on these platforms so why does DNAC report on the errors? Do i need to shutdown the interface before onboarding any 9300's into the platform? Thanks,
2 Accepted Solutions
you mention yo do not use application hosting
DNA wil try to scan for applications hosted on this switch / interface
-> shutdown the Ap interface and hope that helps
guruvignesh
Hello schumad,
DNAC reports input/output errors on AppGigabitEthernet1/0/1 for 9300s, despite not using App Hosting. Consider these steps:
  1. Check interface status: Confirm if interfaces are up and functioning correctly.
  2. Disable unused features: Turn off unnecessary features like App Hosting to prevent error reporting.
  3. Shutdown interface: Temporarily shut down interfaces not in use before onboarding to reduce error reporting.
9 Replies 9
Hi @schumad2ccf
If you check on the switch, does the interface have errors?
sh int Ap1/0/1
It can be a false positive.
I've looked at a few of my switches and yes they have errors but i find it weird that so many of these device have errors on that specific interface.
CC-M-02-200-9300-S3#sho int appGigabitEthernet 1/0/1 | i errors|runts
127 runts, 0 giants, 0 throttles
135 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 output errors, 0 collisions, 2 interface resets
Did you ever find out more about this?  I just did a large deployment of 9300 switches and I getting the same errors on the Application hosting interfaces too.
schumad2ccf
Unfortunately no response or resolution found.
guruvignesh
Hello schumad,
schumad2ccf
Thanks everyone for the input!
radavidson
Yes I see the same behavior on C9K switches running 17.12.3. Short bursts of runts/input errors (30-60 over 10mins) once or twice a day. It must act as a feature, to remind you to disable the app interface, if unused. It would still be nice to understand how an internal interface is logging runts/input errors. Hopefully the errors subside once you install an app.
I'm seeing this on some IE-3200s.  Has anyone found out more information on this feature?  Maybe what sort of impact we may see if we disable the interface?  Mine shows Connected so I don't want to crash a production switch......
