How access switch Urgent!
ccnamonsun
I hv catalyst 2950 switch pulgged into the network unconfigured,
I want to access it through my PC to manage it.How can i manage it
without unplugging from running network , without consol cable or any third party
tools.
you cannot access the switch remotely when there is no management IP address on the switch that is reachable through the network. Physically consoling into the switch is your only option.
GP
mrmozaffari
then do this
en
conf t
int vlan 1
ip add ........ (as you need)(for example 10.1.1.1 255.255.255.0)
no sh
exit
line vty 0 4
password cisco
login
exit
enable secret cisco
ctrl+z
copy run start
and then you can login to switch by telnet to ip address of vlan 1.
Hi mrmozaffari,
I am using CSS11501. I also wanted to access via telnet . How do I do it? It is the same way?
Thanks.
