how assign a 2 vlans in cisco 2960 switch
MSKUMAR
hi,
I need to create 2 vlans 192.168.25.1 and 192.168,26,1
ans assign these vlan to the switch port port 1 and port 3
I'm using CISCO 2960 Catlyst.
Pls. guide the commands thru console .
Hello
ypu dont say if you need to allow communication between the two subnet so I will assume you do
Config t
ip routing
int vlan 25
IP address 192.168.25.1 255.255.255.0
ip route-cache
exit
int vlan 26
IP address 192.168.26.1 255.255.255.0
ip route-cache
exit
int x/x 1
description access-port 1
switchport host
no shut
switchport access vlan 25
exit
int x/x 3
description access-port 3
switchport host
no shut
switchport access vlan 26
end
wr
Kind Regards
Paul
Please breaf : int x/x 1
below is a sample. IP routing has been enabled, if you use a router linked to the switch to do the routing, you need to configure a trunk link to the router and create subinterfaces (Router-on-a-stick)...
ip routing
interface GigabitEthernet1/0/1
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/2
switchport access vlan 3
interface Vlan2
ip address 192.168.25.1 255.255.255.0
interface Vlan3
ip address 192.168.26.1 255.255.255.0
You can also name the vlan
Example:
vlan 2
name data
vlan 3
name voice
