Using SFP-H10GB-CU3M in Cisco 2960S - SFP not supported?
dastrix80
Hi All
The SFP matrix says its supported but I see this in the log:
*Jan  2 00:10:17.312: %PHY-4-SFP_PLUS_NOT_SUPPORTED: The SFP PLUS in Te1/0/1 is not supported
*Jan  2 00:10:17.312: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/0/1, putting Te1/0/1 in err-disable state
Im running the following IOS:
C2960S-Garage#         show ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE8, RELEASE SOFTWARE (fc1)
Any thought as to why this occuring?
C2960S-Garage#show ver
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 23:10 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
C2960S-Garage uptime is 1 hour, 33 minutes
System image file is "flash:c2960s-universalk9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24PD-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1438W0F9
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
26 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : B4:A4:E3:61:70:00
Motherboard assembly number     : 73-12427-07
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC143707FU
Power supply serial number      : DCA1433U1T0
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24PD-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC14371GBL
System serial number            : FOC1438W0F9
Top Assembly Part Number        : 800-32456-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMFF10BRB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24PD-L   15.0(2)SE8            C2960S-UNIVERSALK9-M
Configuration register is 0xF
Kris
pieterh
is this a Cisco brand or third party?
you can try an show inventory or show interface status to see how the SFP is detected,
and you can try the commands from
Unsupported GBIC (SFP) in sub-module of Catalyst 3850 Switch – Mitigation Techniques
that possibly also work for 2960s
- no errdisable detect cause gbic-invalid
- service unsupported-transceiver
Its a Cisco brand, ive tried those commands with the same issue.
C2960S-Garage#show inventory
NAME: "1", DESCR: "WS-C2960S-24PD-L"
PID: WS-C2960S-24PD-L  , VID: V02  , SN: FOC1438W0F9
NAME: "TenGigabitEthernet1/0/1", DESCR: "unknown"
PID: SFP-H10GB-CU3M      , VID: ^A    , SN: MOC16031778
NAME: "TenGigabitEthernet1/0/2", DESCR: "SFP-10GBase-LR"
PID: SFP-10G-LR          , VID: V02  , SN: FNS22200HLH
C2960S-Garage#show interf ten1/0/1 status
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/0/1   "10Gbit Link to QN notconnect   1            full    10G unknown
C2960S-Garage#
C2960S-Garage#
