How can DHCP bindings be saved following reload?
jkrawczyk
Is there any way to have the DHCP bindings on routers to be saved to :nvram or a flash device so that then power is lost and the router reloads, I don't have to manually enter the bindings?
Jeff
Giuseppe Larosa
Hello Jeff,
you can configure the routers to save the bindings on an external TFTP server.
check the ip dhcp database agent feature
Hope to help
Giuseppe
