How can I config Port-channel from ASA to Core Switch and assign IP?
NetworkRookie
I've got 2 ASA and 2 Core Switch stacked. How can I config Port-channel from ASA to Core Switch and assign IP to Port-Channel of ASA, Coreswitch. Look like gateway will be .1 in core and .2 in ASA.
From ASA1, I already used 4 ports from g1/1 - g1/4 for port-channel and g1/1-2 from ASA2
here my config:
Core:
Vlan 101
vlan 102
int range g1/0/45-48
channel-group 1 mode on
int po1
sw trunk encaps dot1q
sw trunk native vlan 101
sw mode trunk
int range g1/0/43-44
channel-group 2 mode on
int po2
sw trunk native vlan 102
sw mode trunk
ASA1:
int g1/1
no sh
int g1/2
no sh
int g1/3
no sh
int g1/4
no sh
int po1.101
vlan 101
ip add 10.1.0.2 255.255.255.248
no sh
nameif Inside
security-level 100
ASA2:
int g1/1
no sh
int g1/2
no sh
int po2.102
vlan 102
ip add 10.2.0.2 255.255.255.248
security-level 50
nameif Internal
and here are subnets for 2 vlan: vlan 101: 10.1.0.0/29 vlan 102: 10.2.0.0/29
7 Replies 7
Mark Elsen
 >... How can I config Port-channel from ASA to Core Switch and assign IP to Port-Channel
          You can't assign an IP address  to a layer2 interface , only to Vlan(SVI)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Light me.
As you said. I can assign IP to int vlan 101 and vlan 102 in CoreSW, so how can I switch int po1 and int po2 access to vlan 101 and 102?
I've read about Cisco ASA 5506 and higher removed vlan, so I can Switch port access to vlan in ASA5506
balaji.bandi
as per your question, you need to do as below on the Core switch :
 interface Vlan 101
ip add 10.1.0.1 255.255.255.248
no shutdown
interface vlan 102
ip add 10.2.0.1 255.255.255.248
no shutdown
is this cluster deployment, then you need cluster link also.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/ha-cluster.html
BB
it's stand alone deployment, not clustering or something like that.
It's a simple network topo ASA1 > Core > ASA2. Stand alone.
That above suggested config should work for you.
BB
I've tried your suggest config but it's not work. maybe I did something wrong.
it depend on
if you want you can config VLAN SVI in ASA
or config sub-interface ins ASA
