I want to see net flow data.
I have configured this command on the c6500.
but I can to see data only below...
How can I configration ip cache flow on the C6500?
what is the problem?
int gi4/31
ip add x.x.x.x
ip route-cache flow
c6500# show ip cache flow
Displaying software-switched flow entries on the MSFC in Module 5:
IP packet size distribution (6108 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .454 .028 .461 .000 .000 .000 .007 .000 .000 .048 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
1 active, 4095 inactive, 2967 added
81020 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33992 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 20 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 18 0.0 78 40 0.0 18.4 8.8
TCP-WWW 2 0.0 3 50 0.0 8.0 8.7
TCP-other 14 0.0 3 50 0.0 9.5 15.4
UDP-other 2918 0.0 1 114 0.0 0.7 14.7
IP-other 14 0.0 28 60 0.0 126.5 3.9
Total: 2966 0.0 1 91 0.0 1.5 14.6
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Gi6/47 10.34.70.2 Null 224.0.0.10 58 0000 0000 325
Displaying hardware-switched flow entries in the PFC (Active) Module 5:
Pkts
