How can i find between source and destination if any switch or router is present?
Ramesh S
When I don't know the network topology how can find if any switch or router is present between source and destination.
Mark Malone
traceroute will show ip based hops  , if its hub or unmanaged you wont see it
cdp if the devices are cisco will help as well or use lldp
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just to add to what Mark wrote, normally CDP and LLDP will only show neighbors connected by L2.  So even if its enabled, assuming you don't have access to transit device, you might only be able to "see" the next device beyond yours.
For traceroute, there are configurations that will "hide" devices, for example, a GRE tunnel won't show physical hops between the GRE end-points.
In other words, it can sometime be very difficult to determine a network's physical topology.
Thanks Mark & Joseph.
