HOW DETERMINE BRIDGE ID
We have two switch cisco  3560 with the same default priotity STP of: 32768.
They have only one vlan configured Vlan 1 (default).
The BPDU will forward the best BRIDGE_ID:
  • both switches have the same priority.
  • but the switch with the less mac-address has the best BPDU.
How do you determine the less mac-address is they in HEXADECIMAL format?
Do you transform it to decimal or olny compare the last octect?
Waiting your sooner answer.
Attn.
Roger Majo
2 Accepted Solutions
Reza Sharifi
Hi Roger,
Compare both mac addresses from left to right.  Lowest number is 0 and the highest is F.
Reza
Roger
Yes you are right.
Jon
Reza Sharifi
Hi Roger,
Reza
Reza,
For example, if the two mac-address are:
MAC_1:001c.0f17.68c0 y
MAC_2:0021.cc4a.70b4
MAC_1 will be the less mac-address so the associated BRIDGE_ID is the best?
0 with 0
0 with 0
1 with 2
Am I right?
Best regard.
Roger
Roger
Yes you are right.
Jon
