How do I apply a static route to a specific interface?
rolandshum
I have a default route 0.0.0.0 but I'd like some packets that come in on certain interfaces to have a different default route.
acomiskey
Level 10
Level 10
If you only wanted 192.168.1.0/24 to use the specific default route on a particular interface, something like this should work.
interface FastEth...
ip policy route-map mymap
access-list 10 permit ip 192.168.1.0 0.0.0.255
route-map mymap permit 20
match ip address 10
set ip default next-hop
Wow, this seems to be a popular answer.
Jon Marshall
You need to use Policy Based Routing for this. Attached is a white paper explaining how PBR works and what it can do. After reading this serach on Cisco site for your IOS version configuration docs and PBR will be in there.
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml
Jon
Amit Singh
Roland,
You can use PBR and match the intresteing traffic using an ACL to have it source routed to a different next hop IP. This way your specific incmoing traffic an interface will be policy routed to a different next hop router and the other traffic which doesnot match the PBR will follow the normal defualt route.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/qos_c/qcpart1/qcpolicy.htm
HTH,Please rate if it does.
-amit singh
JORGE RODRIGUEZ
Level 10
Level 10
You can do this trhough PBR "Policy base routing"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457b9c.html
Jorge
Jorge Rodriguez
acomiskey
Level 10
Level 10
match ip address 10
