CatOS help
shikamarunara
Level 4
Level 4
I am trying to view the interface configs and vlan assignment for interfaces on a Catalyst 4006 with CatOS but I am unfamiliar with CatOS commands. Can someone point me in the right direction?
-Shikamaru
3 Accepted Solutions
Jagdeep Gambhir
Level 10
Level 10
Hi Shikamaru,
Here is the command,
Switch> (enable) sh port 3/1
Check this link
http://www.cisco.com/warp/public/473/53.shtml#Show_Port_for_CatOS_and_Show_Interfaces_
Please rate if that helps !
`JG
To view the mac address table in CatOS
"sh cam dynamic"
You can also put in specific ports, do a
"sh cam ?"
Jon
Since CatOS only functions at Layer2, you will only be able to see arp entries from the VLAN the management interface (sc0) is part of.
The command is show arp.
6 Replies 6
Jagdeep Gambhir
Level 10
Level 10
Hi Shikamaru,
Check this link
`JG
Is there a way to see the MAC address table and ARP table in CatOS? I found a command that looks like it should give me the information (show port x/y), but it doesn't have any MAC addresses in it. I'd just like to know what IP addresses are connected to each interface.
-Shikamaru
"sh cam dynamic"
"sh cam ?"
Jon
How do you view the arp table in CatOS?
-Shikamaru
Thank you all for your help, you have been very helpful.
-Shikamaru
