How do I clear dynamically learned mac addresses from my switch?
kevindo93
I have typed in the following to attempt clearing the dynamically learned mac addresses:
"clear mac address-table dynamic"
"clear mac-address table dynamic"
"clear port-security all interface"
"clear mac address-table"
All of these commands result in "invalid input detected at __ marker"
What am I doing wrong or what information will I need to be able to do what I need to do?
M02@rt37
Hello @kevindo93
The prompt > mean than your are not in the enable mode '#'.
'>' indicates that you are in user EXEC mode rather than privileged EXEC mode. To clear the MAC address table, you need to be in privileged EXEC mode.
Do enable command and enter the command to clear mac address table.
Best regards
6 Replies 6
M02@rt37
Hello @kevindo93
Best regards
I think it worked based off of the screenshot
However, the following question in my lab asks "Do I see any MAC addresses? Why or Why not?"
Based off of that screenshot, it looks like it's still showing the dynamically learned MAC addresses. So, why did the command not clear it?
@kevindo93
Note that Packet Tracer offers simulated IOS with functionality on the grounds of partial features...
Best regards
So, do you mean that it won't clear the mac address table because I'm using packet tracer which is a simulated environment that offers functionality on partial features?
Can you share the
Show port-secuirty mac
MHM
@kevindo93
You do it well with this command !
Test an icmp between 2 PC connected to your Switch. Check the MAC table and do a clear. Observe the table again.
Best regards
