How do I enable NBAR on Cisco 6509-E Sup2T ???
Shlomy Maron
I'm running VSS of 6509-E Sup2T with IOS 15.0(1)SY6 Advance Enterprise.
The command that I'm familiar with "ip nbar" does not exist.
how can I activate it ? and how can I update it ?
I'd like to use it for netflow export.
5 Replies 5
Bilal Nawaz
When you configure flexible netflow, flow record I think you can input an application name
ie
conf t
flow record xyz
match application name xyz
See here
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
thanks for your help.
unfortunately, this command doesn't work.
more than that - I can't even use the command "ip nbar <something>" in order to update the nbar.
does 6500 platform support NBAR ?
I don't believe "ip nbar" command is supported on the 6500.  I tried it on a 6800 with sup 2T and no luck.
See this link. NBAR command is not supported
http://www.cisco.com/c/dam/en_us/training-events/le21/le39/docs/tdw108_qa.pdf
The command you are comfortable with is no longer available.
From this link I got the command reference for application.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-2SY/config_guide/sup2T/15_2_sy_swcg_2T/netflow_hw_support.html?bookSearch=true
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/command/fnf-cr-book/fnf-c1.html#wp2697790240
match/collect application name
To configure the use of the application name as a key field for a flow record, use the match application name command in flow record configuration mode. To disable the use of the application name as a key field for a flow record, use the no form of this command.
no match/collect application name
Command History
Release
Modification
15.0(1)M
This command was introduced.
15.2(2)T
15.2(3)T
This command was integrated into Cisco IOS Release 15.2(2)T for Cisco Performance Monitor.
Cisco IOS XE Release 3.5S
This command was integrated into Cisco IOS XE Release 3.5S for Cisco Performance Monitor.
