how does router connect to ATM switch?
sarahr202
Level 5
Level 5
Hi every body!
In frame relay, router connects to frame relay switch using T1 line. The router may have integrated csu/dsu on T1 card or csu/dsu can be stand alone unit .
1)In ATM network, does router have the intergrated cs/dsu on ATM interface card on router?
2) Does router connect to ATM switch using T1 line?
thanks a lot!
Edison Ortiz
1) Yes, here is one example - this is for T3 (similar can be found for T1):
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps8604/product_data_sheet0900aecd806a2d17.html
2) It's called ATM Circuit and it can be a T1/E1 or T3/E3.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
