how i communicate on different n/w Ip
hello,
i have two link which i terminate on 3 layer switch.
and other one link which i got from firewall, now tell me what ido for communication between this three link
all link address r different
link1 10.10.20.1/24
link2 10.20.20.1/24
link3 10.30.20.1/24
Marvin Rhoads
In short, configure a routing protocol and apply it to the VLANs / IP networks.
If you tell us what model of switch you are using, we can point you to the applicable software configuration guide. That will have more details as to the specific commands you should use.
Hope this helps. Please rate helpful posts.
