How is Formed a Catalyst 3850 Stack
Rosa Ladera
I am working with 4 C385048U boxes.
version: 16.03.05b
Stolz#sh sw stack-ports summary
Sw#/Port# Port Status Neighbor Cable Length Link OK Link Active Sync OK #Changes to LinkOK In Loopback
1/1 OK 4 50cm Yes Yes Yes 1 No
1/2 OK 3 100cm Yes Yes Yes 1 No
2/1 OK 3 50cm Yes Yes Yes 1 No
2/2 OK 4 50cm Yes Yes Yes 1 No
3/1 OK 1 100cm Yes Yes Yes 1 No
3/2 OK 2 50cm Yes Yes Yes 1 No
4/1 OK 2 50cm Yes Yes Yes 1 No
4/2 OK 1 50cm Yes Yes Yes 1 No
Stolz#sh sw
Switch/Stack Mac Address : 706b.b920.0480 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Standby c444.a0e8.8f00 1 V06 Ready
2 Member cc5a.53e8.5d80 1 V06 Ready
3 Member cc5a.5365.7a80 1 V06 Ready
*4 Active 706b.b920.0480 1 V06 Ready
After each reboot logical sw number is different from fisical sw location.
Can someone help to show sw law construction?
Hello
If all hardware,software versions and switch numbers/ priorities are the same then stack election can be dependent on the longest uptime between the members participating in the election and if these are the same then the switch member with the lowest base MAC address will become the master.
Note:
1) switch renumbering depicts the interface numbering of the in the switch stack
2) switch priorities define the preferred role a switch can take within the stack - hugest most preferred
Review here:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html
Res
Paul
Kind Regards
Paul
5 Replies 5
Hello
Switch x priority 15  <   preferred for master switch
Switch x priority 13  <   preferred for standby switch but will become master is master fails
Switch x priority 11  <   preferred for a member switch will become standby if standby fails or become master is both current master and standby fails
Switch x priority 9   <   etc,.....
res
Paul.
Kind Regards
Paul
What is the relation between logical switch number and phisical switch position in the stack?
which law regulates the members choice?
Hello
Note:
Review here:
Res
Paul
Kind Regards
Paul
Thanks.
Now I understand.
I have made tests and worked fine.
Finally a have found out that mode button helps to identify the physical position of each switch in the stack.
Hello
Glad to hear that-
Thank you also for the rating
Kind Regards
Paul
Kind Regards
Paul
