How migrate tunnel?
Does anybody knows any procedure to migrate tunnels between routers 7600?
I mean, in which things should I be careful?
mpls traffic-eng path-option...
dynamic attributes...
And everything related...
Thanks...
Julio E. Moisa
Hi Jose,
May I know the reason to migrate the tunnel? is from a device to other? I see you are using traffic engineering. A golden key is that you need to verify communication between the source and destination (Tunnel-TE the destination addresses) address before to create or migrate a tunnel.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hi Jose,
It is for Load Balancing the traffic in a MPLS Core Network.
