How should I configure my Motorola SBG6580 for use with a Cisco router/switch (model #'s inside)
JoshJ5Hawk1
Hey guys, double ended question here. I got a killer deal at work on a Cisco 2821 ISR a Cisco 2950 24 port switch (Layer 2) ($60 for the pair).
I currently have the setup *working* but I feel it's not quite right. I still have my SBG6580 (Cable Modem) in router mode, because if I flip it over to bridge mode, I lose everything. I have NAT setup on my Cisco Router, as well as a DHCP server. When I do have the setup deployed (currently not using it, as I'm working to get it in a location that isn't my bedroom floor) everything works perfectly fine (including using the DHCP pool on the 2821, somehow. Because from my limited knowledge, double NAT and double DHCP is a very bad thing.
The next question is how do I go about port forwarding with my 2821, instead of my surfboard. The main reason I *am* choosing to use the 2821 instead of just popping the switch on the network, is well, it's more fun (and from what I've read, using a single command to set up the Port Forwarding is faster/easier that screwing with the SBG6580)! I have seen some information about port forwarding around, but I figure since I'm asking the one question, I might as well throw both in.
Thank you all for your time
Mark Malone
Hi put the modem back into bridge mode and follow this doc for port forwarding on cisco side it should work for you
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/260-cisco-router-nat-overload.html
