how to - access list for subnet range
jacob6000
I have been trying to get the syntax right to allow certain outbound traffic based on subnets. the first two lines are fine but I can't get the third and fourth line to take. What is the correct way to do this?
ip access-list extended TEST
 permit ip any host x.x.x.x
 permit ip any host 65.54.54.128 0.0.0.31
 permit ip any host 65.55.127.0 0.0.0.255
Thank you,
Just remove the host keyword
permit ip any 65.54.54.128 0.0.0.127
permit ip any 65.55.127.0 0.0.0.255
permit ip any 65.55.121.128 0.0.0.63
Rolando Valenzuela
mtarawne
Hello
this is not valid as you already using the keyword host and then using wild card mask . we use wild card mask if we need a range .
 permit ip any host 65.54.54.128   this means  permit ip any 65.54.54.128 0.0.0.0
so instead of writing 0.0.0.0 we use keyword host
hope I understood your question correctly
regards,
Not exactly.
I need to permit or deny these ranges only:
65.54.54.128/25
65.55.121.128/27
65.55.127.0/24
What is the syntax?
Rolando Valenzuela
