How to achieve Restriction between SVI
sreeraj.murali
Level 3
Level 3
Hi Experts, Could you please suggest if this is a valid ACL statement.
I want to restrict access from vlan20(172.20.2.0/24 Network) to other vlan. Also need to permit access to my WAN Devices which is of ip address, 172.20.4.2,172.20.4.4 and 172.20.4.5. Please suggest.
If this needs an correction, kindly help.
access-list 199 permit any 172.20.4.0 0.0.0.6 – Access to WAN Gateway
access-list 199 deny any any – Restricting access to other vlan
interface Vlan20
 description XYZ Network
 ip address 172.20.2.1 255.255.255.0
 ip helper address  172.20.2.1
 ip access-group 199 in
Prob betfter putting it both directions so i have altered the acl so there is a reverse rule to so can go in/out
ip access-list extended test
 permit ip host 172.20.4.2 172.20.2.0 0.0.0.255
 permit ip host 172.20.4.4 172.20.2.0 0.0.0.255
 permit ip host 172.20.4.5 172.20.2.0 0.0.0.255
 permit ip 172.20.2.0 0.0.0.255 host 172.20.4.2
 permit ip 172.20.2.0 0.0.0.255 host 172.20.4.4
 permit ip 172.20.2.0 0.0.0.255 host 172.20.4.5
 deny   ip any 172.20.2.0 0.0.0.255
 deny   ip 172.20.2.0 0.0.0.255 any
 permit ip any any
interface Vlan20
ip access-group test in
ip access-group test out
8 Replies 8
Mark Malone
if i understood that correctly allow the wan devices speak to vlan 20 but vlan 20 then blocked from speaking to erveryone else , if the wan devices are just to speak to the host ip you can alter it  , apply it in and outbound under the interface
 permit ip any any
By the way your helper address shouldnt be the vlan interface , it should be the dhcp server address and if the dhcp scop is on the device then you dont need the helper
interface Vlan20
Thanks Mark for the prompt response!!!
Yes Mark, I need to have vlan 172.20.2.0/24 communicate only to 172.20.4.2(MPLS Router), 172.20.4.4(Internet Firewall), 172.2.4.5(Internet Router) for accessing the Internet as only Internet access should be allowed from this vlan. Hope your answer achieves the same result.
Please help me with the below queries as well
1. On which interface I need to apply the ACL?
2. Yes, the dhcp pool is running on the same switch where the vlan interace 172.20.2.1 is configured.
Please find the below diagram for more clarity
[cid:image001.png@01D34295.080DF890]
Kindly suggest.
so the way that's written is each of the first 3 host rules .2 .4 .5 can talk to vlan 20 anybody else is denied in the second last line and then everyone else can speak to each other.
It should be applied on the vlan 20 interface itself
Your image is not viewable but if the scope is local you don't need to use the helper address , its only required when dhcp server is on a different vlan like 10.10.10.x so then you would need to point to that under the vlan interface so it can change from broadcast to unicast and reach the dhcp server, if that makes sense
Thanks!!!
So the interface vlan should like below ? Please confirm.
interface Vlan20
ip access-group test in/out - please confirm it access group should be applied IN or OUT?
 permit ip any any
interface Vlan20
Thanks a lot Mark!!!
I will try this and update you.
Sreeraj
I believe you will need to make a couple of changes:
access-list 199 permit ip any 172.20.4.0 0.0.0.7
access-list 199 deny ip any any
interface Vlan20
ip access-group 199 out
Just bear in mind that the above ACL permits traffic destined to 172.20.4.0/29 network only.
HTH,
Meheretab
HTH,
Meheretab
Thank a lot Meheretab. I will try and update.
Sreeraj
