How to add 4 3750 into existing stack ?
r.sagredo
I have 3 3750  staking swtich with the folowing configuracion:
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
1       Member 442b.0350.9400     1      1       Ready
2       Member 442b.0357.8780     2      1       Ready
*3       Master 442b.036f.a800        3      1       Ready
The new switch is installed to be wired to the master switch. the swtich 3 (* 3 Master Ready 442b.036f.a800)
my question is: if you disconnect the wiring from the master stack to connect to the new switch, it is possible that the new switch change the current configuration of stacking.
-Can I just add the new switch with clean configuration without changing the current configuration ?
-how is assigned the stack number? i need the new switch be with the GI4 / x?. I can I manually by assigning ports?
-If I want to the new 3750 member witch lower prioridad, can I change priority before adding to stack?
Thanks in advance,
singhaam007
Level 3
Level 3
Reza Sharifi
singhaam007
Level 3
Level 3
Hi Raul,
hope this will help as its same scenario as yours.
https://community.spiceworks.com/topic/251174-adding-a-new-switch-to-an-existing-stack
thanks
