How to block assigning a dhcp ip to perticular host
prasanga123
I have a 1841 cisco router as a dhcp server with 2 address pools
namely abc & xyz
ip dhcp pool abc
network 10.20.4.0 255.255.255.0
default router 10.20.4.1
ip dhcp pool xyz
network 192.50.201.0 255.255.255.0
default router 192.50.201.1
Router is connected to a cisco 2960 switch. It has 2 vlans associated
with the 2 address pools.
I have a manual binding to server.
ip dhcp pool serv
host 10.20.40.5
client-identifier xxx.xxx.xxxx.xx
when i connect the server to a switch port which is associated with
the abc pool it gets the correct manally binded ip.
when i connect it to a switch port which is associated with the xyz
pool, it get an ip from that pool. But i want the router to assign
only the binded ip when connected to a port associated with the abc
pool. If the server is connected to the other vlan port, then it shoul
not get an ip.
How can i do this. Please help
andrew.prince
Level 10
Level 10
I think you could try:-
1) Create a dhcp pool in the xyz pool, but configure no information apart from the client-identifier. When the server tries to request an IP - the router will not assign one.
2) Create a mac address filtering ACL in the VLAN sub-interface in the router for the xyz, blocking the server MAC address from accessing the routers MAC address.
The above are off the top of my head - I have not tested either of the above, you may want to.
Please explain what you mean by "Create a dhcp pool in the xyz pool" & how to do that.
I tried but could not do.
I understand ur 2nd option & i am sure that will work.
Thanks.
Just tested in the lab and option 1 will not work. You cannot assign a specific client host into a dhcp pool for a IP subnet.
Option 2 could still work.
Another option would be to use the vlan/switch port to bind the server into the specific vlan - something like port security would work.
Or the best solution would be not to move the server connection into a switch port in the other vlan.
HTH.
