how to block facebook using 887G-K9
firestormnet
I was trying to implement a web site blocking for sites such as facebook and youtube, but with no luck.
You have blocked the ip range, but in that range could be some useful sites, so you won't be able to access them.
May be implementing of Access Lists will do the same job.
Cheers,
David Carr
Level 6
Level 6
Firestormnet,
Have you tried blocking based on key words under the firewall tab.
There should be an option under firewall/content filtering/blocked Urls.  Under that tab, select key words and put facebook and youtube in the entry.
This should block those sites for you.
Hi David.
I didn't use SA520 security appliance, I used 887G-K9 router CLI commands, so it's different I suppose. I tried to connect the router to CCP, but it didn't except userID and PWD to login (don't know why, even default cisco-cisco), as I thought there will be some options for  firewall or filtering aplications.
