How to bypass tacacs on console connection in cisco nexus 9000
Ramirov
Hi guys , I need to connect via console without pass/user or with local user/pass , but I have tacacs configured for all lines , I tried with aaa authentication login console none  , but I think I have problems with aaa autho..
Should I remove the line aaa authorization commands console group TACACS+ local??
This is my actual config. Nexus 9000
aaa authentication login default group TACACS+
aaa authorization config-commands default group TACACS+ local
aaa authorization commands default group TACACS+ local
tacacs-server directed-request
Thanks in advance.
BR
Giuseppe Larosa
Hello Ramirov,
try the following
aaa authentication login CONSOLE local
line con 0
login authentication CONSOLE
Edit:
this is how it works on IOS. the command under the line con 0 is login authentication <name>
Hope to help
Giuseppe
Hello Giuseppe , is not the same on NXOS.
switch(config-console)# login ?
No matching command found in current mode, matching in (config) mode
in-failure Set options for failed login attempt
on-success Set options for successful login attempt
Hi Ramirov,
Are you able to solve this one? facing the same issue...
Yep ,
I add aaa authentication login console local and remove aaa authorization commands console
