How to check if 3750 switch support enhanced PAgP for VSS dual-active detection?
gwhuang5398
Level 2
Level 2
I have a 3750 stack switch I can connect to a 4500X VSS pair for dual-active detection. How can I check if the 3750 supports enhanced PAgP?
Reza Sharifi
PAGP is supported if you are connecting a single switch (3750) to VSS, but if you are connecting a stack (2 3750s with one connection from each 3750 to VSS) only LACP is supported.
