How to check temperature on Cisco 877 router
johnlloyd_13
Level 9
Level 9
hi experts,
i would like to know if there's any way i could check the operating temperature on a Cisco 877 router. Thanks!
Greetings John,
There is no temperature sensor on the 877 router, sorry! The 877 is suited to operating in an environment between 32 and 104°F (0 and 40°C).
/Phil
Did you try with show environment?
Best regards.
Massimiliano Serafino.
hi,
yes, but it's not supported.
IROUTER#sh envi?
% Unrecognized command
ROUTER#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI3, RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 14-Sep-05 15:29 by ealyon
Greetings John,
/Phil
hi phil,
thanks for your feedback! i read somewhere on d net that indeed there's no temperature sensor on this router.
