How to configure automatic failover between two connection (access) internet in cisco routeur 2800 serie?
josedunet
hello all,
How to configure the automatic failover between two connection (access) internet in cisco routeur 2800 serie?
Best Regards,
Nagendra Kumar Nainar
If you have 2 internet connections terminating on 2800 router, you can simply configure 2 default static route pointing to next hop and have load balance the traffic to Internet.
or, you can configure 2 default static route, one with default Administrative Distance (Your Primary ISP) and other with higher Administrative Distance (Secondary ISP) as below,
ip route 0.0.0.0 0.0.0.0
ip route 0.0.0.0 0.0.0.0 254
HTH,
Nagendra
HTH,
Nagendra
thanks naikumar,
How can i load balance the traffic to Internet ?
Best Regards,
Configure 2 default static route without changing the administrative distance. Router will install both the default route in table and will perform load balancing.
HTH,
Nagendra
