how to configure GLBP works as HSRP
cscyangyu
My company want to use the GLBP to load balance the traffic , but for some reason , We want to configure the GLBP work as the HSRP , make 2 router 1 active and another is standby . Does anyone know how to configure the GLBP works as HSRP?
Giuseppe Larosa
Hello Angyu,
unless a single client is present in the Vlan (for example a firewall) GLBP will attempt to load balance
you could configure router2 in such a way that it does not forward  (by tracking a non operational interface for example) but this would mean it will not be able to take over if the primary fails
see
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_glbp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054488
otherwise you could with weighted load balancing algorythm have most of traffic on R1 and only a few on R2
maximum
Maximum weighting value in the range from 1 to 254. Default value is  100.
so you could configure 254 on R1, 10 on R2 and you could get 25:1 traffic ratio with  algorythm
glbp group load-balancing weighted
GLBP priority elects the AVG and weigthing decides how to load balance if using the above algorythm
you can consider to use VRRP if you want a standards based first hop redundancy protocol
see
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_vrrp_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello Angyu,
see
maximum
see
Hope to help
Giuseppe
