how to configure ip sla on cisco switch
jfantasia
I'm running IOS 12.2(33)SXI on SUP 720 3C and I'm configuring ip sla for icmp-echo. Here's my ip sla configuration:
ip sla 62
icmp-echo 10.0.0.62 source-ip 10.1.1.1
timeout 300
frequency 2
history filter failures
ip sla schedule 62 life forever stat-time now
The script runs fine when I don’t have a failure. So when I have a failure with the pings, it's reporting the number of failures but when the network connectivity returns, the ip sla script continues to report failures. My firewall logs tell me the ip sla script stopped pinging but the script continues to report failures. What must I do in the ip sla configuration for the ip sla script to start pinging after a failure?
julijime
Hi  jfantasia,
Actually you don't need to perform any changes on the 6500 in order to resume the ip sla operation. Given your configuration, the keyword "forever" schedules the sla operation to run indefinitely.
After the connectivity is restored after a failure the Number of successes counter will keep increasing, if your 6500 keeps failing that would mean that your switch is still not able to reach it's ip sla destination.
  • During the failure:
6513#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 00:18:56 UTC Wed Sep 17 2014
Latest operation return code: Timeout
Number of successes: 82
Number of failures: 76
Operation time to live: Forever
  • After the failure:
        Latest RTT: 61 milliseconds
Latest operation start time: 00:18:58 UTC Wed Sep 17 2014
Latest operation return code: Over threshold
Number of successes: 83
Hope this helps!
