12-16-2015
02:21 AM
- last edited on
03-25-2019
04:36 PM
by
ciscomoderator
Hello?
My name is Daniel.
I want to config port-channel on Nexus9504.
Could you show me how to configure port-channel between N9K-X9464PX with N9K-X9464TX on N9K.
Below is N9K information.
switch# sh mod |
Mod Ports Module-Type Model Status |
1 52 48x1/10G SFP+ 4x40G Ethernet Module N9K-X9464PX ok |
2 52 48x1/10G-T 4x40G Ethernet Module N9K-X9464TX ok |
switch(config-if)# sh int eth 1/48 |
Ethernet1/48 is up |
admin state is up, Dedicated Interface |
Belongs to Po1 |
Hardware: 1000/10000 Ethernet, address: 0462.7385.aa1f (bia 0462.7385.aa1f) |
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec |
reliability 255/255, txload 1/255, rxload 1/255 |
Encapsulation ARPA, medium is broadcast |
Port mode is trunk |
full-duplex, 1000 Mb/s, media type is 1G |
switch(config-if)# sh int eth 2/48 |
Ethernet2/48 is down (suspended) |
Belongs to Po1 |
Hardware: 100/1000/10000 Ethernet, address: 84b2.61ad.c3d7 (bia 84b2.61ad.c3d7) |
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec |
auto-duplex, 10 Gb/s |
O-IDC-N9K_2(config-if)# sh port-ch summ |
Flags: D - Down P - Up in port-channel (members) |
I - Individual H - Hot-standby (LACP only) |
s - Suspended r - Module-removed |
S - Switched R - Routed |
U - Up (port-channel) |
p - Up in delay-lacp mode (member) |
M - Not in use. Min-links not met |
Group Port- Type Protocol Member Ports |
Channel |
1 Po1(SU) Eth LACP Eth1/47(P) Eth1/48(P) Eth2/48(D) |
Thanks.
12-16-2015 09:30 AM
Hi Daniel
Please see :-
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0111.html
You indivual interface mst basically be the same, IE same speed & duplex.
Your interfaces are showing one as Gig/Full and the other is 10Gig/auto.
These must be the same.
Alex
12-17-2015 10:38 AM
Hi?
Thanks for comment.
I resolved following steps.
If speed auto then interface eth2/47 and 2/48 doesn't join the members of the port channel.
N9K_1(config)# int eth 1/47 - 48 , eth 2/47 - 48
N9K_1(config-if-range)# sw
N9K_1(config-if-range)# sw mod tr
N9K_1(config-if-range)# channel-group 1 mod ac
N9K_1(config-if-range)# no sh
N9K_1(config-if-range)# sh port-ch summ
Channel
1 Po1(SU) Eth LACP Eth1/47(P) Eth1/48(P) Eth2/47(D)Eth2/48(D)
N9K_1(config-if-range)# sh int po1
port-channel1 is up
admin state is up,
Hardware: Port-Channel, address: xxxx.yyyy.zzzz (bia xxxx.yyyy.zzzz)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec
Port mode is trunk
N9K_1(config-if-range)# sh int eth 2/47
Ethernet2/47 is down (suspended)
Belongs to Po1
Hardware: 100/1000/10000 Ethernet, address: xxxx.yyyy.zzzz (bia xxxx.yyyy.zzzz)
Port mode is trunk
N9K_1(config-if-range)# int po1
N9K_1(config-if)# speed 1000
N9K_1(config-if)# sh port-ch summ
Channel
1 Po1(SU) Eth LACP Eth1/47(P) Eth1/48(P) Eth2/47(P)Eth2/48(P)
N9K_1(config-if)# sh int po1
port-channel1 is up
admin state is up,
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec
Port mode is trunk
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth1/47, Eth1/48, Eth2/47, Eth2/48
N9K_1(config-if)# sh int eth 2/47
Ethernet2/47 is up
Belongs to Po1
Port mode is trunk
N9K_1(config-if)# sh int eth 2/48
Ethernet2/48 is up
Belongs to Po1
Port mode is trunk
Thanks.
04-02-2018 09:47 AM
This describes how to configure port channels and to apply and configure the Link Aggregation Control Protocol (LACP) for more efficient use of port channels in the Cisco NX-OS devices.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_0110.html
