How to configure PPPoE on CISCO 831 with my ISP
cristianlinca
Hello there,
For some reason I messed up my home router and now I only have a CISCO 831 available and I would like to configure PPPoE on it and to use it as my home router from now on.
The question is that I don't know how to configure it, I found some useful links on the internet but everytime I tried to follow the steps, at some point, my router didn't had some of the options on the command line.
I, most likely, have a dynamic IP from my ISP and I use a username and a password to connect to internet.
Here is the start-up config that I have so far but don't know how to make it work, what should I do more to make it work over internet?
Using 971 out of 131072 bytes
version 12.4
no service pad
hostname Home831
boot-start-marker
boot-end-marker
enable password XXXXXXXXXXX
no aaa new-model
resource policy
ip subnet-zero
ip cef
vpdn enable
bba-group pppoe global
interface Ethernet0
no ip address
shutdown
interface Ethernet1
no ip address
shutdown
duplex auto
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
login
no modem enable
line aux 0
line vty 0 4
password cisco
logging synchronous
login
scheduler max-task-time 5000
end
In case you need more info, please ask.
Cristian
I did that, followed the post, configured as follows but still cannot connect:
version 12.2
no service pad
hostname 831
logging queue-limit 100
ip subnet-zero
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LOCALPOOL
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description Inside private interface
ip nat inside
hold-queue 100 out
interface Ethernet1
description Connection to DSL Modem ISP
no ip address
ip tcp adjust-mss 1452
load-interval 30
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp pap sent-username "my username without qotas" password 0 "my password without qotas"
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
What is wrong? Can you please tell me what I have to do more?
Thanks Cristian
