How to configure SPT ( in our side ), to connect to ISP Layer 2 links
bensonlei
Hi, guys,
ISP provides a internet line to my company, for the last mile WAN link ( their customer end), they provide two layer 2 lines connecting to our two separated C2960 switches ( as below ):
ISP -----L2 Switch Line 1   -------- C2960-1 (vlan 10)  ---- Our Layer 3 device1
               L2 Switch Line 2   -------- C2960-2 (Vlan 10)  ---- Our Layer 3 device2
For our C2960 switches:
1. C2960-1 (vlan 10) --trunked---C2960-2 (vlan 10);
2. Both C2960 switches enables the cisco default pvst.
3  Layer-3 devices/Firewall in  Active-Active mode.
4. At this moment, all switch ports connected to ISP Layer 2 switches are in "forwarding" state, we have not yet configured the trunk for this vlan, ( network loop occurred if we configured trunk for vlan 10, this is verified ).
SW1 & SW2 configuration:
interface GigabitEthernet0/1
 description To Internet line
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
 spanning-tree bpdufilter enable
interface GigabitEthernet0/7
 description To Inter-SW trunk
 switchport trunk allowed vlan 94,96,98,99
 switchport mode trunk
ISP side:
1. We do not know what device they use for their Layer 2 network,
2. We do not know their device configurations,
3. We found the same some ISP MAC addresses  from our switches.
How we configure our Layer 2 switches ( interfaces and trunk ), so one switch port (connected to ISP ) is in "forwarding" state (active), another port is in "blocked" state ( standby ) for resilient links for ISP connection ?
Mark Elsen
  - Such setups (intrAnet concepts) are not advisable when making a connection to an ISP which is basically L3 based. Have  a look into routers and firewalls which can use techniques such as BGP or  PBR (policy based routing) for redundancy purposes.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
It is not layer 3 concern.
ISP demarcation ( or ISP modem ) provides 2 network lines ( for redundancy network -) to our C2960 switches:
If we allow vlan 10 in trunk, network loop occurs.
How we configure the switches, for preventing network loop but providing resilient network connection, thx ?
1>We do not know what device they use for their Layer 2 network,
2. >We do not know their device configurations,
   - Indeed , sometimes Layer2 setups are used BUT, then you need all sufficient information from the ISP to set this up. The above items must be resolved 'without diplomacy' ; otherwise working on it makes no sense. Get sufficient information from the  ISP.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
