How To Configure???
alsayed
Hi Netpro
How to configure the following?
1)other AS may be directly connected to AS100.configure r1 to accept
bgp routes from backbone 1 that originate only in AS 100 and may other AS
directly connected to AS100. all other BGP routes should be filtered . use a filter -
list with only 1 regular expression to accomplish this.
2)Configure so that TELNET may be possible from R3, R4, SW1, SW2 to loopback 1 of R2
(155.4.13.1/24) , available in one router for this
All traffics that occur in loop (155.4.13.1/24) must become block, not include telnet traffic
enter only
Telnet connection for a maximum of 30 second, after 30 second, the connection
should be
close and all of telnet connection should be audit
3)R1 & R3 are connected via F/R.configure ipv6 on both routers but the Ipv6 traffic doesn't traverse the frame-relay interfaces.configure ripng between these 2 routers
Thanks a lot for ur help
