How to connect a ASUS wifi-router to a Cisco RV 325 Router
I had simple TPlink router that was spreading internet through my flat to 2 asus wifi routers. everything was working fine. Simple plug and play connection.
Now I've brought Cisco RV 325 router And trying to put it at the beginning of my flats network this is upgrade of old TPlink.
So Cable goes into flat -> CICSO RV 325 -> multiple cables to PC,ASUS routers,other devices.
Connected my PC cable. PC gets internet.
also accessing 192.18.1.1 setup just fine.
Plugged in Asus routers - No internet. Both routers cannot get any internet
Probably I should configure something additionally in CISCOs setup ?
Giuseppe Larosa
Hello @DavidChachava66962 ,
first of all verify physical level OSI L1 then OSI level 2.
Are the ports connected to the ASUS routers showing a green solid LED or are they not showing anything ?
If RV325 do not support auto cross connect you may need an ethernet cross over cable to have a link up/up between two router interfaces.
Edit:
refer to the following admin guide
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/Updated/rv32x_ag_en.pdf
and CLI guide
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/CLI_guide/rv32x_cli_guide.pdf
Hope to help
Giuseppe
