How to connect Cisco SF 300 to Vigor Draytek 3900
Hari Nguyen
Dear all !
I have problem when trunk cisco SF 300 to router Draytek Vigor 3900 . My Network as bellow image :SF300-3900.jpg
 At SF 300 I created  Vlans VLAN 250 :10.0.0.0 VLAN 10 :10.0.10.0 VLAN 30 : 10.0.30.0 and VLAN 300 : 192.168.200.0 .In case VLAN 300 used trunk to Router Vigor 3900 (IP 192.168.200.254) .I created route on SF 300  0.0.0.0 0.0.0.0 192.168.200.254 .But when i connect SF 300 to Vigor 3900 All Vlan SF 300 can not ping to Draytek 3900 .Pls help me solve this problem .Thanks so much !
This is my config on SF 300 :
ip domain name SERVER-DATA
ip name-server  10.0.0.254
ip telnet server
interface vlan 1
 no ip address dhcp
interface vlan 10
 name XNK
 ip address 10.0.10.1 255.255.255.0
 ip dhcp relay enable
interface vlan 20
 name L1-UP
 ip address 10.0.20.1 255.255.255.0
interface vlan 300
name Route
ip address 192.168.200.1 255.255.255.0
interface gigabitethernet 1
 switchport mode access
 switchport access vlan 300
ip route 0.0.0.0 0.0.0.0 192.168.200.254
Seb Rupik
Hi there,
If your diagram is correct (and the Vigor is configured as such), then Gi1 need to be configured as a trunk interface:
int gi1
  switchport trunk allowed vlan add 300
  switchport mode trunk
cheers,
Seb.
Dear Seb !
Thanks for your help ! I will try it !
I don't think this is going to work. Your SF300 is in Layer 3 mode, which essentially makes it a router. Your Draytek is a router as well, so you will need to confiigure a layer 3 link between both devices, or set the SF300 to layer 2 mode, create the VLAN interfaces on the Vigor, and then configure a trunk link.
In order to create a routable interface on the SF300, check page 274 of the attached user guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
thanks for your help ! i will try !
