How to console into 2960 switch?
MicJameson1
Hello.
I am unable to console into a 2960x switch.
-This switch has no IP-addresses configured.
-There is no serial console port.
-I don't have a mini-USB cable.
-There is an RJ45 console port on the lower left corner of the front.
-I have a USB-to-RJ45 console cable. I downloaded driver Cisco_usbconsole_driver_3_1, then connected my workstation with the USB side, and the RJ45 side to the console port. (I don't know if this is serial emulation technology.) Putty config:
COM1
speed: 9600
data bits: 8
stop bits: 1
no parity
flow control: xon xoff
I've tried various other putty configs besides serial because I don't know how this RJ45 console technology works.
This link seemed like it would be helpful, yet has not succeeded for me....
https://www.reddit.com/r/Cisco/comments/emggzl/logging_into_a_catalyst_2960x_series_switch/
May you please help?
Thank you.
@MicJameson1 wrote:
"Unable to open connection to COM1
Opening '\\.\COM1': Error2: The system cannot find the file specified."
Try different COM ports.
Use Device Manager to determine which port the computer has assigned the USB-to-Serial cable to.
5 Replies 5
balaji.bandi
Check this console cable port -
try  - flow control: xon xoff  ( to none)
Is this a new or used one?
Check is the SWITCH booted as expected with LED :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/hardware/installation/guide/b_c2960x_hig/b_c2960x_hig_chapter_01.html
if the system LED green - you should see some console messages.
BB
This is an active production switch.
There are no lights illuminating at all on the console port.
I confirmed that both ends of the cable are firmly seated in the ports.
When I try to log in with flow control: xon xoff  ( to none), I receive the same error...
This is an active production switch.  - so is this switch working as expected ? then you can do SSH if you know the IP address, or you don't know that information ?
ok - when you connect the USB cable to PC, (in the corner right bottom it will tell you what com  port it has allocated)
or you can go settings - Bluetooth& other device, it will show you what com port for this USB (I am sure its not com1)
There are no lights illuminating at all on the console port.  - I do not believe console port you see the any LED
I am asking about the SYSTEM LED ?
BB
Leo Laohoo
There is also a mini-USB console port.  There is no need to buy a Cisco specific USB Type-A to min-USB.  Any USB Type-A to min-USB will do.
