how to create an ACL for dynamic nat
dannan lin
hi
i want to setup a ACL to deny a certain access from a particular ip range.
bu this ip range shares same addresses from same nat pool.
in this case how do i write ACL? since i can not specify the source address.
here is brief config file:
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 182.168.2.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.99.1 192.168.99.10
ip dhcp pool managment
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip dhcp pool finance
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
ip dhcp pool sales
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
ip dhcp pool customer_exp
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip nat inside
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.3
encapsulation dot1Q 30
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.10
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
ip access-group 1 out
ip nat inside
interface FastEthernet1/0
ip address 192.168.4.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
router rip
version 2
network 192.168.4.0
no auto-summary
ip nat pool my_nat 192.168.4.10 192.168.4.200 netmask 255.255.255.0
ip nat inside source list 2 pool my_nat
ip classless
access-list 1 deny 192.168.2.0 0.0.0.255
access-list 1 deny 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit any
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.2.0 0.0.0.255
access-list 2 permit 192.168.3.0 0.0.0.255
access-list 2 permit 192.168.99.0 0.0.0.255
if i want to deny the access of 192.168.2.0 /24 to 192.168.5.10 ,how do i write ACL and place it  on the f0/0 of router 3 ?
thanks in advance .
2 Accepted Solutions
Hi Dannan,
You can do like below what I have in my router and working as desired.
ip nat pool NONAT 192.168.4.10 192.168.4.200 netmask 255.255.255.0
ip access-list extended NONAT
deny ip 192.168.2.0 0.0.0.255 host 192.168.5.10
permit ip any any
Please rate the helpfull posts.
Naidu.
yes you can do it like this as this tells the router which traffic to nat depending on a match with a permit statement in the ACL.
Regards.
Alain
9 Replies 9
Marwan ALshawi
Nat happens after acl
So simply use acl like the below and apply it to fa0/0
Access-list 100 deny ip 192.168.2.0 0.0.0.255 192.168.5.0 0.0.0.255
Access-list 100 permit ip any any
Interface fa0/0
Ip access-group 100 in
Or you can apply it under fa0/0.2
Hope this help
If helpful rate
Hi Dannan,
Please see the attached link, which shows the Order of Operation of NAT on Cisco IOS devices.
An INBOUND access-list (ip access-group ACL in) is checked Before NAT
An OUTBOUND access-list (ip access-group ACL out) is checked After NAT
So this gives you options for matching against 'Real' or Translated IP addresses.
Hope that Helps,
Nick
thanks for your help, but i am wondering if i can do it with dynimic nat ?
why don't you just configure an extended ACL for the dynamic NAT:
access-list 199 deny ip 192.168.2.0 0.0.0.255 host 192.168.5.10
access-list 199 permit ip any any
ip nat inside source list 199 pool my_nat
This way as traffic from 192.168.2.0 to host 192.168.5.10 will not get natted you are preventing communication between this subnet and this host.
Regards.
Alain
Hi Dannan,
permit ip any any
Naidu.
thanks naidu, appreciate your help.
thank you for your help guys. but if i want only deny www service to the 192.168.2.0/24 .
can i write
access-list 199 deny tcp 192.168.2.0 0.0.0.255 host 192.168.5.10 eq www
i am not so sure if i can do that because the way nat works is to change the IP header , if my access-list is based on the tcp then it probably won't work , but it is just my assumption. correct me if i am wrong .
regards
Regards.
Alain
thanks alain, you are the man.
