How to create subinterface on a 3560
ud0508500
I am trying to create subinterfaces on a 3560 switch on gi0/1 interface..Can some please help? thank you !!!
current ios is flash:c3560-advipservicesk9-mz.122-44.SE2.bin"
I want to be able to create the following:
interface GigabitEthernet0/1.20
interface GigabitEthernet0/1.30
interface GigabitEthernet0/1.40
etc etc
I have used the no switchport on the gi0/1 interface as well and it keeps rejecting the command
Switch(config)#int gigabitEthernet 0/1?
.  :  <1-2>
Switch(config)#int gigabitEthernet 0/1.
Switch(config)#int gigabitEthernet 0/1.20
% Invalid input detected at '^' marker.
Switch(config)#
Switch#sh run
Building configuration...
Current configuration : 1330 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description **** Create sub interfaces ***
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Switch#
Reza Sharifi
Unfortunately, you can not create sub-interface on 3560s or 3750s.
Reza
Thank you for the information..appreciate the help..it seems there are options
to do so with the IOS..but it just does not take..thanks
Jon Marshall
You don't need to create subinterfaces on a L3 switch. Instead make the port a trunk port and then create a L3 SVI for each vlan you want to route eg.
int gi0/1
switchport mode trunk
int vlan 10
ip address 192.168.5.1 255.255.255.0
int vlan 11
ip address 192.168.6.1 255.255.255.0
etc. for each vlan. So where you would create a subinterface with an IP addressc create a L3 SVI as above.
Jon
Thanks for your help..appreciate everyones feedback and quick responce..thanks again!!!
