How to disable call-home feature on 4948
Ivan Marinovic
I would like to disable this log massage:
an 16 07:35:15.714: CALL-HOME-DETAIL: Alert group 2 is valid(6)
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Checking if alert-group 3 is supported
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Alert group 3 is valid(6)
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Checking if alert-group 4 is supported
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Alert group 4 is valid(6)
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Checking if alert-group 5 is supported
Jan 16 07:35:15.714: CALL-HOME-DETAIL: Alert group 5 is valid(6)
Jan 16 07:35:15.714: CALL-HOME-DETAIL: unlock call home database sempahore
Jan 16 07:35:35.110: CALL-HOME-TRACE: Received event: 1
Jan 16 07:35:35.110: CALL-HOME-TRACE: Cleared rate limit counter
Jan 16 07:35:35.110: CALL-HOME-DETAIL:
httpc_enabled 1, status 0, sid 2
Jan 16 07:35:37.939: CALL-HOME-TRACE:  show_call_home_summary_func() is called
Jan 16 07:35:37.939: CALL-HOME-TRACE: call_home_get_global_database() is entered
Jan 16 07:35:37.939: CALL-HOME-DETAIL: lock call home database semaphore
Jan 16 07:35:37.939: CALL-HOME-DETAIL: unlock call home database sempahore
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 0 is supported
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Alert group 0 is valid(6)
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 1 is supported
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Alert group 1 is valid(6)
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 2 is supported
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Alert group 2 is valid(6)
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 3 is supported
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Alert group 3 is valid(6)
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 4 is supported
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Alert group 4 is valid(6)
Jan 16 07:35:37.939: CALL-HOME-DETAIL: Checking if alert-group 5 is supported
Jan 16 07:35:37.939: CALL-HOME-TRACE: call_home_get_profile() is entered profile
Jan 16 07:35:37.939: CALL-HOME-DETAIL: call_home_get_profile() found profile
I did:
no call-home
All configuration under call-home mode are set to default value. Cisco TAC profiles are deactivated and all other profiles are removed.
and disable all alert groups
But I am still receiving log massage.
Is there any way to disable them.
sh call-home
Current call home settings:
    call home feature : disable
    call home message's from address: Not yet set up
    call home message's reply-to address: Not yet set up
    vrf for call-home messages: Not yet set up
    contact person's email address: Not yet set up
    contact person's phone number: Not yet set up
    street address: Not yet set up
    customer ID: Not yet set up
    contract ID: Not yet set up
    site ID: Not yet set up
    source ip address: Not yet set up
    source interface: Not yet set up
    Mail-server: Not yet set up
    Rate-limit: 20 message(s) per minute
Available alert groups:
    Keyword                  State   Description
    configuration            Disable configuration info
    diagnostic               Disable diagnostic info
    environment              Disable environmental info
    inventory                Disable inventory info
    syslog                   Disable syslog info
Profiles:
    Profile Name: CiscoTAC-1
Ivan
matyijoe1
workaround: I do not have this problem anymore, because I set the logging severity level debugging --> informational. (logging trap informational)
matyijoe1
thanks, it is working!
