How to display a Russian text in a gateway console?
Igor1906
We are using the Cisco gateway C2851 integrated with Nuance ASR via MRCP. When we attempt to view a Nuance ASR recognition result for a Russian utterance we see on a gateway console screen strange symbols like "P4P0" instead of a Russian text, in this case "yes" in Russian. We tried to change different display options in the gateway console, but no luck. Also we tried to use different telnet consoles like SecureCRT, Putty, Tera Term, etc. but recieved the same result. Our Cisco guys said us that the problem is with the Cisco gateway, i.e. the gateway cannot correctly process a Cyrillic text, in particilar a Russian text. Is it true? How can we resolve this problem?
Please note a Russian text is encoded with UTF-8.
Thanks.
Igor
-- best regards, Igor
Giuseppe Larosa
Hello Igor,
I'm afraid cisco console is tied to english alphabet as the console primary purpose is to allow configuration and troubleshooting of the router itself.
Make appropriate changes in order to access the appliance from a linux box or other computer system that can use unicode or UTF-8.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Igor,
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your help.
Unfortunately I recieved the same result under a linux box.
Nikolay
