How to do PBR on an ASR9001
Hi Everyone,
I have an ASR9001 router and I need to make an exception to the routing table so incoming traffic on G0/0/0/9 that is destined to the subnet 10.10.10.0/24 is sent to 172.16.1.1 as a next-hop. I want to do PBR but ASR9001 is not ISO-based and I have no idea how to do it. Can someone please help me and translate the following commands so they can be applied to an ASR9001?:
ICN_Edge (config)# ipv4 access-list 101 permit ip any 10.10.10.0 0.0.0.255
ICN_Edge (config)# ipv4 access-list 101 permit icmp any 10.10.10.0 0.0.0.255
ICN_Edge (config)# route-map TEST permit
ICN_Edge (config-route-map)# match ip address 101
ICN_Edge (config-route-map)# set ip next-hop 172.16.1.1
ICN_Edge (config-route-map)# end
ICN_Edge (config)# config t
ICN_Edge (config)# interface GigabitEthernet0/0/0/9
ICN_Edge (config-if)# ip policy route-map TEST
Thank you so much
Daniel
Hello.
Please review ACL base Forwarding article.
Very late thanks!, I thought I had sent it before
