How to enable mutlicast in cisco nexus 9000 switch ?
kothalanka
Please help me to enable multicast in cisco nexus 9000 switch, i didnt work on nexus OS and i am facing difficulties on configuration.
please give me temple of sample config how to enable multicast on nexus 9000 switch.
thank you in advance.
regards,
Naresh Kumar.
Marie Killen
Moved discussion to LAN, Switching and Routing Community Support.
Marie
Abhishek Soni
Basically the question you have asked does not mention any design requirement. However you can try enabling 'feature PIM' and use the following guide. Moreover the multicast concept is same on all platforms just command syntex are bit changed.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/multicast/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide_chapter_011.html
