How to enable UPNP on CISCO routers - 36XX
onpage3cisco
How to enable UPNP on CISCO routers - 36XX , How can I simualte UPNP connections.
johnlloyd_13
Level 9
Level 9
I've had the same inquiry from a client. Although, it was for an 1841ISR.
It turned out it is not supported on enterprise class router such as the ISRs.
UPNP is supported and more common in SOHO type routers.
Thanks I understand.
Now Is there a diffrent way to simulate UPNP router ?
