How to filter certain logs?
Hi all,
Can someone help me to get solution with my issue?
I have a cisco 3750X switch and I want to filtering certain prases in log buffer. I don't want recieve them in log buffer.
I tried to use such rule, but no results:
logging discriminator nolog mnemonics drops %SFF8472-5-THRESHOLD_VIOLATION:
9 Replies 9
Mark Malone
hi  haven't tested this but you could try below
logging discriminator TEST msg-body drops %SFF8472-5-THRESHOLD_VIOLATION:
logging buffered discriminator TEST
Hello
I have tested this and Mark is correct, with 1 addition it looks like you require "  " between the msg body drops although it doesn't show up in the running config
logging buffered 4096 7
logging discriminator TEST msg-body drops "%SFF8472-5-THRESHOLD_VIOLATION:"
logging buffered discriminator TEST 7  <----------severity level
res
Paul
Kind Regards
Paul
Thank's for replies.
I did such configuration:
service timestamps log datetime localtime
logging buffered 100000 informational
aaa authentication login default group ACS1 local
but I'm still recieving notifications:
May 24 09:00:19: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.1 dBm, Threshold value: -17.0 dBm.
May 24 09:02:59: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.0 dBm, Threshold value: -17.0 dBm.
May 24 09:10:19: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.0 dBm, Threshold value: -17.0 dBm.
May 24 09:13:00: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.0 dBm, Threshold value: -17.0 dBm.
logging buffered discriminator TEST 7 (you have logging buffered 10000 info) is missing, you need to tie the discriminator to the buffer
Hi Mark,
I did changes, but no changes:
#sh run | i log
sh logg
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Active Message Discriminator:
No Inactive Message Discriminator.
    Console logging: level debugging, 32196 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 1016 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 583 messages logged, xml disabled,
                    filtering disabled, discriminator(TEST),
                     0 messages rate-limited, 0 messages dropped-by-MD
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 32196 message lines logged
        Logging to 10.241.16.206  (udp port 514, audit disabled,
              link up),
              32112 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.241.16.158  (udp port 514, audit disabled,
              link up),
              21416 message lines logged,
              filtering disabled
        Logging Source-Interface:       VRF Name:
        Vlan100
Log Buffer (4096 bytes):
er low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm.
May 25 07:54:26: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 07:59:17: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm.
May 25 08:01:41: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm.
May 25 08:04:26: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 08:11:41: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm.
May 25 08:14:27: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 08:21:42: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm.
May 25 08:24:27: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 08:29:19: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power low warning; Operating value: -17.0 dBm, Threshold value: -17.0 dBm.
May 25 08:31:43: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -17.0 dBm.
May 25 08:34:28: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 08:41:43: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm.
May 25 08:44:29: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.1 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 08:49:20: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power low warning; Operating value: -17.1 dBm, Threshold value: -17.0 dBm.
May 25 08:51:44: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm.
May 25 08:54:29: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
May 25 09:01:44: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm.
May 25 09:04:30: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/3: Rx power low warning; Operating value: -17.2 dBm, Threshold value: -17.0 dBm. (TT-HQ-ACS-3750-HSRP-2)
That should work looking at the docs theres no other config required , the only other thing you could try is change the facility level from debugging 7  , try 1 of these below instead of 7 see if the alerts are coming in under some other level.
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/htnmsylg.html#wp1056441
 <0-7>              Logging severity level
  <4096-2147483647>  Logging buffer size
  alerts             Immediate action needed           (severity=1)
  critical           Critical conditions               (severity=2)
  debugging          Debugging messages                (severity=7)
  discriminator      Establish MD-Buffer association
  emergencies        System is unusable                (severity=0)
  errors             Error conditions                  (severity=3)
  filtered           Enable filtered logging
  informational      Informational messages            (severity=6)
  notifications      Normal but significant conditions (severity=5)
  warnings           Warning conditions                (severity=4)
  xml                Enable logging in XML to XML logging buffer
Hi there
Did you finally solve the issue with the discriminator. The command to tie the discriminator to the buffer overwrites the configured buffer size. So I can only type "one" line....
Thank you
Bart
gabor.somlai
Hi all,
The format of the log is: %facility-severity-MNEMONIC:msg-body
In your case "%SFF8472-5-THRESHOLD_VIOLATION:" has these parts:
facility: SFF8472
severity: 5
mnemonic: THRESHOLD_VIOLATION
You should try this:
logging discriminator nolog facility drops SFF8472 severity drops 5 mnemonics drops THRESHOLD_VIOLATION
Yes, It works. Thanks.
