How to filter log entries?
Hi everybody.
Is there any way to filter what's getting logged? Particularly, I would like to get rid of dot1x authentication failure messages, like these:
000271: Feb 27 12:40:18: %MAB-5-FAIL: Authentication failed for client (b499.baf6.abbc) on Interface Gi3/0/37 AuditSessionID AC1E20AA0000001200038F36
000272: Feb 27 12:40:18: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (b499.baf6.abbc) on Interface Gi3/0/37 AuditSessionID AC1E20AA0000001200038F36
I know that above messages are "legal" or "expected behavior" because of running "open authentication", so I'm not interested in having those filling up my logs on the syslog server. In case of need, I still would be able to set logging back...
Any help will be appreciated.
Flavio.
Can you try that with "logging monitor warnings" instead?
Because you are using "terminal monitor" command...
HTH,
Dragan
HTH,
Dragan
6 Replies 6
Dragan Ilic
Level 4
Level 4
You can try with "logging severity" if it's not impacting other requirements:
http://www.ciscopress.com/articles/article.asp?p=101658&seqNum=3
I suppose we are talking about IOS off course...
HTH,
Dragan
HTH,
Dragan
Hi Dragan.
Thanks for your suggestion. In fact, I could try to change the logging severity, but it might impact on other log messages.
Is there any resource which shows which kind of log record pertains to which severity level?
I would like to get rid of the mentioned log entries, but still need to have log entries when bpduguard is err-disabling a switchport...
I believe you understand what I want to achieve and yes: we're takling about IOS (on a 3850 Catalyst).
Flavio.
You can see from message that it's severity 5...
Maybe you can use this community thread:
https://supportforums.cisco.com/thread/2166887
You can use "FAIL" instead of "SUCCESS" like in example in thread...give it a try...
In this linke example:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/esm/command/esm-cr-book/esm-cr-a1.html#GUID-B7887982-361D-4C8E-BAAF-977AEC1C78EA
you could see how to filter all severity 5 messages also...
HTH,
Dragan
HTH,
Dragan
Hi again Dragan.
I've successfully lowered the severity level for syslog (logging buffered warnings) but the same didn't work for console output (logging console warnings): when I do "term moni" I still see severity 5 messages.
How would I get rid of that too?
Thanks and regards,
Flavio.
HTH,
Dragan
HTH,
Dragan
Great Dragan, that's what I was looking for!
Now I did this:
conf t
end
Thanks and regards,
F.
