How to find the product description with a valid serial number?
hgier
hello
i have a list of serial numbers for switches and routers. how can i get a valid product number e.g. WS-C2960X-24PS-L for this number?
The product was not sold by us and i do not have an valid support contract for that devices.
Any idee for me?
Hans
acampbell
Try
show version
<SNIP>
Power supply part number: 34-0967-02
Motherboard serial number: CAT0833037R
Power supply serial number: DTH08275WEG
Model revision number: P0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CATXX8Y0VM
Configuration register is 0x10F
Alex
Regards, Alex. Please rate useful posts.
johnlloyd_13
Level 9
Level 9
hi,
you can also use show inventory command.
Charles Hill
I'm sure you have obtained the needed information, but you can also go to
Tools & Resources -> Device checker -> and enter the serial number and it will give you the product number and if its covered.
Hope this helps.
